Volvo 850 one too much fixing ? Topic is solved
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
Hy Buddies,
Hope you're all find.
Recently, my slave cylinder, the one on the pedal clutch side, failed. I've ordered a new one and the slave cylinder gearbox side too by the same way.
I've unbolted everything inside the car, behind pedals, included the brake booster, thinking it could be helpful to extract the pedal slave cylinder engine bay side. But I can't move the unbolted brake booster. There is a hose on the white cap I can't unplug, and so I don't also not know where it could be attached to ?
The positif point of this story is that I've successfully managed to save properly the brake fluid without to make a mess. I'm not gonna use it anyway, but,'ve taken it out properly. I've seen Robert DIY's video on the subject, but it doesn't help , I'm afraid to brake something if I force too much.
Advices would be appreciate...
Manov
Nota : few questions :
Nota 2 :
to where does this hose connect to ?
Has thanked: 1609 times
Been thanked: 4065 times
The cylinder on the pedal side is called the master cylinder, just like the brakes.
The master cylinder generates the pressure to work the item (clutch or brake) , the slave cylinder receives the pressure from the master and operates the clutch or brake.
The thick hose is vacuum hose right from the manifold - it sucks the air out of the booster, leaving the atmospheric pressure to help you apply the brakes when requested.
If you put a plier with some teeth on the black hose and rotate it back and forth, being careful not to put sideways force on the connector, it will slowly come off the white fitting. It is just barbed fitting (tuyau BarbelÈ, merci?)
If you really worry about breaking it, you can cut the hose and insert a standard coupling fitting into it, too.
manovlov
Post by manovlov »
"barbelé".
Hey abscate, thanks so much for your help. I've decided to make a break because when I start to see that things don't get the way I want... I didn't know I used to know so much insults in my own language ! ...
Tomorrow is another day. Slowly, with patient, I will managed to solve my issue. Pics to come.
Merci infiniment !
Manov
manovlov
Post by manovlov »
Hy Buddies,
The work on my 850 goes on. I've succeeded to extract the leaking pedal master cylinder, and to re install the new one. I've also replace the seal on the pipe line and re install the clip.
As a newbie, i've forgotten to watch out to which where thes three hoses that come on the master cylinder were connected. I didn't fill up the brake fluid tank for the moment, waiting for a picture to see which hose goes where, a picture or an explanation.
I've seen a diagram on the web, but it doesn't correspond to my brake fluid tank.
A pic or explanation would be helpful.
Thanks to allo you.
Manov
manovlov
Post by manovlov »
So. Restauration is not mechanic stuff : it's love, grease and blood !
I finally succeeded I changing these f*¨%_°ing parts unaccessible for a newbie like me, less newbie operation after operation.
Manov
Volvo 850
Ever.
