96 960 engine ticking Topic is solved
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I have ticking at the top of my engine and someone's resolution was to change the oil with 10 w 30 synthetic and it seems that it worked for a bunch of people but it did not solve the problem for me. The engine is still ticking. I've heard that this is just lifters, which makes sense, but I want to know multiple solutions to the ticking.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- RickHaleParker
- Been thanked: 978 times
Ticking lifters on the older six cylinders is a common issue. The O-ring on the oil pick up tube goes defective. When this happens it is like sucking on a straw with a hole in it. Not enough oil gets to the lifters to keep them pumped up. Solution ... new O-ring for the oil pick up tube.
Active
Past
Past
- CIK7
Thank you so much!RickHaleParker wrote: 21 Aug 2020, 00:28 Ticking lifters on the older six cylinders is a common issue. The O-ring on the oil pick up tube goes defective. When this happens it is like sucking on a straw with a hole in it. Not enough oil gets to the lifters to keep them pumped up. Solution ... new O-ring for the oil pick up tube.
- 404 Views
- 1152 Views
Last post by sleddriver
- 1047 Views
Last post by bluebossa
- 11 Replies
- 3430 Views
Last post by Rattnalle
- 1743 Views
Last post by June
