I trust FCP, but I am coming across some confusion regarding part numbers, namely that the part numbers for Contitech belts on the FCP website do not match what the Contitech website says.
The Car:
1998 V70 Non-turbo
Automatic trans
Has AC
Are these just new part numbers between Continental and Contitech? I know there was a change for the early 850s.
I'm not going to even supply any of the part numbers I have found. I am looking for someone who KNOWS for certain what I need for this car.
Serpentine Belt Confusion
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
All U.S. market models.
All running and on the road.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Continental & Contitech is the same.
Conti also.
Continental Conti are tyres,Contitech are belts(rubber and plastic).
I have Continental serpentine belt installed 2 years ago.
I'll check the numbers from the belt if you want.
It should be 6PK 1743.
https://www.ebay.com/itm/Continental-6P ... =188785425
Conti also.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
RobertDIY posted recently that the continental or conitech serpentine belts have changed at FCP and are too tight causing too much stress on the pulleys. He said he had to cut one off because he couldn't remove it. Not sure if its the same part number.
- misha
I just checked....yes it's Contitech(Continental) 6PK 1743.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Fro Roberts video feed..aug 08, 2020
Belt 6PK 1740 fits better. Not as tight. (4060685) Really doesn't make sense to me why a belt that is suppose to be shorter fit easier. The right belt should be 1752mm, 69 inches.
- misha
As abscate said....it's insane that longer belt fits tighter than shorter belt.
Proper length and part# is 6PK 1743 for whatever brand of belts.
6PK=6 channels
1743=length of the belt.
6PK=6 channels
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I had a similar experience in 2015 trying to install a new Contitech serpentine belt that was marked 1743 on the cardboard packaging but 1740 on the belt itself. IPD was good about that, offering me a full refund. Here's the note that I got from them at the time explaining the labeling error at the supplier:
Hi Jason,
Sorry about that! I was just alerted via my purchasing guys that Continental sent us a batch of these belts that were labeled incorrectly and were slightly too short to install on the car. As we don't have any of these on the shelf and are still working this issue out with Continental, I can't just send you a new one unfortunately so I'm going to go ahead and refund you for the original purchase of the belt as it is incorrect. Sorry about that!
Let me know if I can help you with anything else, or if you have any more questions!
Jared Lohnes
Customer Service Agent
ipd
P: 503-257-7500 x 1xx
F:
E: [email protected]
Hi Jason,
Jared Lohnes
ipd
F:
- Eddystone
FCP suggested the 6PK 1743 serpentine belt for my car.
Contitech Website specifies the following belt for 1998 2.4 auto with AC:
Supplier: CRP/Contitech
Part Number: PK060685
Part Type: Serpentine Belt
Comment: w/AC
1743 mm
68.62 inch
Dayco recommends:
Poly Rib Belt
Part Number: 5060690
Attributes Specifications
Rib Profile W Profile
Metric Part 6PK1755
Effective Length (in) 69.09
Top Width (in) 0.82
Thickness 0.17
No. of Ribs 6
Rib Depth Standard
Compound EPDM, Aramid Reinforced
Backside Material Rubber
Comment: w/AC
1743 mm
68.62 inch
Dayco recommends:
Poly Rib Belt
Metric Part 6PK1755
Top Width (in) 0.82
Thickness 0.17
No. of Ribs 6
Rib Depth Standard
- Has thanked: 311 times
- Been thanked: 817 times
Conti 1743 for my P80 cars.
Dayco makes quality belts but it's maybe not worth the confusion on sizing, I use what everyone else is using ...
- 20 Replies
- 17448 Views
Last post by Hurtfeelings
- 21 Replies
- 5332 Views
Last post by viper69
- 22 Replies
- 35906 Views
Last post by erikv11
- 62 Replies
- 17848 Views
Last post by Shanestrait
- 33 Replies
- 10000 Views
Last post by Krons
