Harmonic Pulley Noise xc70
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Got a whirring noise coming from my sepentine belt, used a rubber hose and its coming from the crank/harmonic balancer pulley.
Sound disappears when i remove the serp belt.
Belt and tensioner look in good condition.
Usually i would just go ahead and change both out but i need to cut costs.
Question is if i get a new belt and tensioner then find the noise is coming from the harmonic balancer??...do harmonic balancers fail in this way?
I describe it as a whirring but i guess its a intermittant (with engine revs) rubber squeaking type sound.
I have a spare balancer (pic) but CANNOT get that nut off....
siezed nut harmonic balancer
Reason: Lowercased Subject. Please no ALL CAPS Subjects.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
How are the pulleys on the serp belt ? Gave each a spin by hand ? The AC compressor pulley is likely to get noisy past 100k miles (if the clutch plate was already removed it may get bent and also be rubbing).
Is the large timing belt cover maybe rubbing at the crank pulley ? Does the lower engine mount look in good condition ?
Maybe also make sure it's not from that metal line passing nearby.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
The small timing pulley cover can stay in place. I recently changed my timing gear behind the harmonic balancer, I didn't touch the cover bolts. If the balancer pulley is secure I'd look more at the serp belt tensioner pulley.
Spraying with water can reveal which one is making noise as its running.
Has thanked: 1611 times
Been thanked: 4072 times
A 30 mm impact is the way to get this off. Hit it with penetrating oil first and let it soak for a day
