Late Manufacture ETM Programming Needed ?
Cillyman
- Year and Model: V70. 1999 Base N/T
I have purchased a used ETM that was manufactured in 2018 and pulled from the exact same car and engine as the failing ETM a V70 1999 5 cylinder non turbo. What are the chances that it will not need to be reprogrammed ? Thanks Scott in MA.
The general stat for a junkyard ETM success rate is 20% but NA is higher, like 80%, last I reviewed.
