O2 sensor
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
I know I'm not suppose to Yell H elp, but oh my God my O2 sensor wires on the adaptor end towards the engine came out and these are all green wires except for 1 black wire. It looks like I can stick them back up in the adapter but I don't know where the wires go correctly. My O2 sensor is in connected and fine, what do I do????? The sensor wires are BLK white grey and maybe another white. Please......!
- RickHaleParker
- Been thanked: 980 times
Two of the green wires should have stripes One stripe is gray and the other is black.
The two White wires on the sensor side are the heater. Polarity does not matter.
ECM to O2 Sensor.
Green-Gray to Gray. (Sensor (-) in ECM).
Green-Black to Black. (Sensor (+) in ECM).
Green to White. ( Heater (+) in ECM, shared with fuel injectors and others).
Black to White. ( Heather (-) in ECM ).
ECM to O2 Sensor.
Active
Past
Past
- Has thanked: 1611 times
- Been thanked: 4074 times
If it didn’t plug and play into the Volvo harness, it’s probably a junk OXS which won’t work well.
You can confirm Ricks wiring in the wiring diagram ( findable on the web, not hosted here by agreement with Volvo) as Rick is wrong approximately 0.00000850% of the time
- RickHaleParker
1994 850 EWD is document TP3903202 .
Active
Past
Past
loveMy850
Hi Rick, I have to buy a new harness, I have to get the pins and I'm wondering what size pins they are, I don't like wiring of any kind after have the s**t shocked out of me years ago. Male and female are the pins, which goes into which wires. Thank you ..
loveMy850
Hi Rick, I have to buy a new harness, I have to get the pins and I'm wondering what size pins they are, I don't like wiring of any kind after have the s**t shocked out of me years ago. Male and female are the pins, which goes into which wires. Thank you ..it's not the sensor it's the harness... The pins are bad, bad connection, did a code reading and got 212 it needs repaired badly.
loveMy850
loveMy850 wrote: 08 Sep 2020, 21:14 Hi Rick, I have to buy a new harness, I have to get the pins and I'm wondering what size pins they are, I don't like wiring of any kind after have the s**t shocked out of me years ago. Male and female are the pins, which goes into which wires. Thank you ..it's not the sensor it's the harness... The pins are bad, bad connection, did a code reading and got 212 it needs repaired badly.
loveMy850
I'm unsure which pins to buy are they certain pins size, make all that stuff? Male female, it looks like they were just yanked out, I don't know whats going on, the harness that holds the pins to the wires to the engine, please can you help me..
What year and model engine are we talking here??
Maybe someone has an old sensor they can send for the connections ?
