Releasing a bolt of the engine ideas?
Mikele82
Year and Model: XC70 04 + C30 T5 08
Has thanked: 30 times
Been thanked: 3 times
Post by Mikele82 »
This B bolt is stuck, im affried to break it (the teath seem to be be about the break,
any solvent or such to release? or good tool to bolt release?
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
You need to be using a TORX driver or bit for that fastener. Hex/Allen keys will round it out.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Mike Langlois
Year and Model: 2002 V70 & V70 XC
Has thanked: 28 times
Been thanked: 6 times
Post by Mike Langlois »
Try an impact driver; it would be my next step.....
https://www.amazon.com/648002-Dr-Impact ... 2525&psc=1
Manic MIke
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Ditto on using the properly fitting torx bit. Another thing that can help is to take a small punch - small enough to fit down into the bottom of the torx hole - and give it a couple of good raps with a hammer. What that does is slightly push the screw shank downward, in relation to the head, and relieves some of the load on the threads.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Recently managed to mangle 3 long Philip head bolts on a motor bicycle tranny case.
Got all 3 easily, even with mangled heads using air hammer fitted with a "shake and break."
famfeld
Year and Model: 04 xc70
Has thanked: 9 times
Post by famfeld »
Make sure your using the right torx bit and a good quality one that fits well w/o too much play. Then plenty of penetrating oil. Get a 12" 3/8 in extension and tap it with a hammer. Vibrations should help it and also help to seat the torx bit into the screw. Should come out but good your being careful to strip.
Has thanked: 1609 times
Been thanked: 4065 times
Increasing escalation of battle....
15 seconds with propane torch to heat it up
A non harbor freight Torx bit, brand new.
Vice grip, needle nose style
Dremel and off with its head
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
using heat is a good idea, but be careful of a fire especially if using petrol based penetrating oil. best try it when engine is hot.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
