Bump sound when reversing XC70 in morning....?
a73s
Year and Model: 850T 1995
Post by a73s »
Hi,
I have an XC70 2006 with about 100k miles on it. It's in pretty good shape.
I've noticed recently that I often hear a "bump" when I reverse out of my garage in the morning...sounds like it's coming from the rear drivers side. Almost like I ran over something...It usually occurs after I've reversed about one to two feet.
If I'm out driving later I don't hear it...seems to be only in the morning?
Any idea what this could be?
Thanks,
Alan.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
a73s wrote: 04 Sep 2020, 22:55 Hi,
Thanks,
Alan.
I would check the brake caliper slider pins.
... the center retainer bolt that holds the drive shaft in the wheel hub.
and the drum brake shoes, they can lose the shoe liners.
More likely to be brakes.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Best is to ask someone to do this (reverse) while you stand outside listening to the noise.
Very often the noise one hears in the cabin is different when one is outside.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
a73s wrote: 04 Sep 2020, 22:55 I often hear a "bump" when I reverse out of my garage in the morning...Almost like I ran over something...
Any pets, children, or mothers-in-law missing?
Has thanked: 1609 times
Been thanked: 4064 times
Are you setting your parking brake when you park?
If not, it’s probably delaminated
a73s
Post by a73s »
abscate wrote: 05 Sep 2020, 20:19 Are you setting your parking brake when you park?
No, actually hardly ever set the park brake....(should I?).
Live in the midwest so it's flat around here for miles!!
Thanks,
a73s
Post by a73s »
[/quote]
[/quote]
Thanks, I'll look into this.
a73s
Post by a73s »
cn90 wrote: 05 Sep 2020, 12:29 Best is to ask someone to do this (reverse) while you stand outside listening to the noise.
Hmm, yes probably a good idea too, try to nail down the exact source of the noise.
Thanks.
