Hit a pothole today then every bump I hear a horrible banging
bronco
Year and Model: 1998 V70
Has thanked: 49 times
Been thanked: 24 times
Post by bronco »
1998 V70 . Driving about 30mph , hit a pothole or raised manhole cover and heard a loud BANG !!! pull over looking underneath expecting to see broken control arm or strut but I see nothing wrong. Drive away slowly nothing then hit another pothole BANG! step on the brakes horrible grinding noise.
I'm only about 5 miles from home so I limp home jack it up tire doesn't move everything seems ok so I remove the tire and look and the edge of the rotor looks weirdly shiny . go to take a caliper bolt out , put the allen in twist the ratchet and the caliper moves !
Long story short the lower caliper bracket bolt is gone and the upper bolt is half out of the hole. :roll: basically every bump was bouncing the caliper and bracket up and down pivoting on the remaining bolt and using the brakes was pulling the caliper too far in on the bottom bracket making the caliper touch the edge of the rotor
Ive owned the car about 2 years I have never touched the brakes the PO did them. He gave me the receipts new everything pads calipers rotors CV joints etc.
He did a lot of work to the car but had a big oil leak from the turbo line and from a cam seal( he had installed backwards) and gave up basically.
Anyway I went to the other side and both caliper bracket bolts were hand loose .
About a year ago I had a few lugnuts fall out and the loose ones were covered in a black goo , these caliper bolts had the same substance on them.
He apparently did not want his threaded fasteners to seize and made sure they wouldn't with whatever this crap is.
I feel for the guy , I have seen these stupid lug bolts freeze in so tight they snap off when you put a wrench on them. And I have seen caliper brackets you needed to heat with a torch on these cars too.
Whatever the black goo is , it looks nothing like any standard axle type grease i have ever seen .
Tomorrows project will be looking through the receipt pile and checking various bolts . :?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Black goo is probably grease.
I use antiseize on caliper bolts and wheel lugs now for > 25 yrs. Zero issues.
Has thanked: 1609 times
Been thanked: 4063 times
Unconfirmed, but I believe Volvo says to replace these when removed and the torque is in the tty regime.
Confirmed. Volvo says replace, 100 Nm torque
bronco
Post by bronco »
I always use anti seize on those too. It wasn't like grease though it was a strange feel to it , almost sticky .
Like the texture of honey .
maybe something old-timey
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Cosmoline ?
1999 V70 GLT
Mother in law saying
“ let me out!!!”
bronco
Post by bronco »
Sveedy wrote: 05 Sep 2020, 17:27Cosmoline ?
maybe! cosmoline with brake dust in it would be black huh?
Has thanked: 2196 times
Been thanked: 1850 times
I thought the caliper bracket bolts use thread locker on them? I have re-used these bolts for years many times with no issue. Please note I am not advocating others do this but my personal experience is they can be re-used. These take less stress on them than the caliper slider pins which have a muck smaller thread diameter.
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
Dang bronc that stinks! Unless you thoroughly enjoy checking the torque of all your bolts that is.
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
