Hello, can advise me as to what is causing this? Both front tires almost down to the wire on the inner edges and sidewall after 9k miles. Just put new ones on and booked in for tracking, though I suspect something is worn out.
New control arms and no movement in tie rods or bottom joints. Car does wander on highway.
Thanks
Matt
V70 200,000 miles.
Abnormal tire wear..
Free2drive!
- Year and Model: 2007 XC90
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
mine does that on one rear wheel, tire has a slow leak and settles around 20 PSI.Free2drive! wrote: 08 Sep 2020, 04:37 Hello, can advise me as to what is causing this? Both front tires almost down to the wire on the inner edges and sidewall after 9k miles. Just put new ones on and booked in for tracking, though I suspect something is worn out.
Thanks
Matt
V70 200,000 miles.
Severe sidewall scuffing, I'd keep an eye on pressure but as it occurs with 2 of yours its probably something more mechanical in common than pressure.
Free2drive!
Thanks jonesg. I’ve got my eye on it..I’ll see what the tracking machine says and report back.
Matt
Matt
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
Your camber (chamber) is completely wrong.
Look at this 3 minute video:
This is what's wrong with your car. Somebody loosened the camber adjustment hardware and got distracted from their work.
Or it may have been done maliciously.
Too bad your tyres got trashed.
Those tyres are beyond illegal anywhere.
Free2drive!
Thanks Georgeandkira, I need to look at getting camber measured and adjusted. Would 2mm or 3mm be enough to cause the tire wear?
That looks like bad toe in to me, not camber, I should say toe out.
Front of tires are wider than rear of tires
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
its not rubbing when full lock??....get an alignment and get rid of those tyres.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Free2drive!
Update! Booked in for alignment on Thursday morning.
I’ll post results back as soon as I’ve got them.
Thanks for advice and comments.
Matt
Matt
I think you are right , Darryldarrylrobert wrote: 09 Sep 2020, 07:50 its not rubbing when full lock??....get an alignment and get rid of those tyres.
That’s rubbing, not alignment
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I don't think the OP would not notice that kind of rubbing for almost 10K miles. It's toe out plus low inflation. Wandering is a sure sign of toe out whereas negative camber inner tire wear will keep the car straight. The center of the tire seems beefy compared to the inner and outer edges.abscate wrote: 22 Sep 2020, 02:46I think you are right , Darryldarrylrobert wrote: 09 Sep 2020, 07:50 its not rubbing when full lock??....get an alignment and get rid of those tyres.
Just finished a DYI four wheel alignment on our C30 including rear camber and toe before Son went of to college.
(EDIT:) I would of also liked to have considered it rubbing due to the excessive amount of wear but the orange arrow part of the tire is from alignment whereas the yellow looks more like tire rub. Could be a combo as it really needs to be looked at from various angles.
- 11 Replies
- 2509 Views
Last post by icrashcars
- 12 Replies
- 3338 Views
- 964 Views
Last post by S40VolVo01NC
- 980 Views
Last post by Boosted40
- 298 Views
Last post by CIK7
