Hello folks, hope you all are managing the mask era good enough!
Out of the blue, my check engine light came on, with no message in the message window. Looking around on the gauges, I realized the temperature gauge is not working; the pin is way down to the left. What might this be?
Thanks.
Check Engine Light With Not Working Temperature Gauge
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
Could be as simple as a failed engine coolant temperature sensor (ECT)
That would probably also generate an engine error code and your light
Oka
The temperature sensor fail is what I was suspecting also. The other thing would be the thermostat, but this I think, if it fails, would give a wrong temperature on the gauge.abscate wrote: 08 Sep 2020, 04:50 Could be as simple as a failed engine coolant temperature sensor (ECT)
By the way, this morning, I drove it from one spot to another, just about 30 feet drive and the auxiliary fan came on.
Thanks for your reply.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
i wouldnt worry about the fan working, there is no way the car can overheat after 30 feet, i know AK can get hot.I would check the easiest thing first is the sensor on the engine housing then you may need to take the DIM apart.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Oka
How can I check the Engine Temperature Sensor, except to replace it?darrylrobert wrote: 10 Sep 2020, 06:01 i wouldnt worry about the fan working, there is no way the car can overheat after 30 feet, i know AK can get hot.I would check the easiest thing first is the sensor on the engine housing then you may need to take the DIM apart.
I had replaced the "Water Temperature Sender" back in September 2019.
Thanks.
Oka
Just found how to test the sensor. Will do the tests and report.Oka wrote: 10 Sep 2020, 11:05How can I check the Engine Temperature Sensor, except to replace it?darrylrobert wrote: 10 Sep 2020, 06:01 i wouldnt worry about the fan working, there is no way the car can overheat after 30 feet, i know AK can get hot.I would check the easiest thing first is the sensor on the engine housing then you may need to take the DIM apart.
Thanks.
