Hey! I bought a C70 that was side-reared and after the fix i got it with the cables just hanging there.
I will link some pictures of it.
I havent connected the ones in the pictures.
The black ones seem to be for the GND, but i am not sure to where to attach them.
The deal here is with the blinkers. When i press the brake pedal, the blinkers start to blink weird, if at all. Otherwise when the brake pedal is not pressed on, the blinkers work just fine.
Help?
I couldnt add the pics here, so i posted them on imgur(
C70 wiring diagrams? Got some plugs hanging "in the air" in the
eightfifty2x0
- Year and Model: 1996 850
- Has thanked: 10 times
- Been thanked: 3 times
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
What is weird, like blink fast, or dim? Take a multimeter and measure the voltage when you push the brake pedal vs not pushed on the blinker. It might be a weird relay issue.
2008 S60 2.5T Auto (Sold)
eightfifty2x0
I dont have a second person to help me... And somebody on the local forums told me that the parking assistant might be damaged... But without diagrams i cannot really do anything. I could measure the voltage everywhere, but what would take a looong time and would not really help meyanga001 wrote: 13 Sep 2020, 19:54 What is weird, like blink fast, or dim? Take a multimeter and measure the voltage when you push the brake pedal vs not pushed on the blinker. It might be a weird relay issue.
yanga001
Can you leave a phone recording behind the car and then post the video or take still images? A picture is worth a 1000 words in this case.
eightfifty2x0
Will do it later this day. Gonna reply to this messageyanga001 wrote: 14 Sep 2020, 07:35 Can you leave a phone recording behind the car and then post the video or take still images? A picture is worth a 1000 words in this case.
- Stu70
- Year and Model: 2006 Sonic VR GT
- Has thanked: 34 times
- Been thanked: 26 times
They look to be the ground terminals, under the carpet there will be some bolts/screws into the metal work that are in a position that lines up with those ring terminals.
Your rear lights have no ground so the return power from indicators or brake lamps is running through other lamps, which causes those lamps to dim and do weird stuff.
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
eightfifty2x0
Hmm, interesting. I will look into it tomorrowStu70 wrote: 14 Sep 2020, 10:44 They look to be the ground terminals, under the carpet there will be some bolts/screws into the metal work that are in a position that lines up with those ring terminals.
eightfifty2x0
This is how bad it is...
- Has thanked: 1613 times
- Been thanked: 4075 times
Classic bad ground, nice call m Stu
- 1276 Views
Last post by MadeInJapan
- 59 Replies
- 33556 Views
Last post by Twarr12000
- 1161 Views
Last post by Philgault
- 1060 Views
Last post by Eddystone
- 3217 Views
Last post by RickHaleParker
