Hello everybody ,
I am in the Middle of a T belt replacement Service with a Supercharger reseal service and replacing the front crankshaft Seal.
Working with Alldata and identifix but both platforms cant provide me any specs for torque specs . Hopefully i can find some help here since the Volvo dealerships around here wont give any Information . i am looking for the Specks for Camshaft Sprocket to Camshaft Bolt , Timing belt Tensioner and idler pulley for T belt .
Hope anybody can help me with any infos.
thank you
Volvo XC90 4 Cyl B2404t27 Torque Specs T Belt Service
- RickHaleParker
- Been thanked: 977 times
B2404T27 ... Volvo never made a 2 cylinder 4.0 Liter engine.
With the stroke the VEA engines have that would require 165mm pistons .
Specs from B4204T12 should be the same for a B4204T27.
Timing belt: Tensioner and Idler bolts 24 Nm.
VVT: Center bolts 90 Nm.
Active
Past
Past
haha my bad ,
was just typing a bit to fast at that moment and flip the numbers lol .
Thanks a lot for the specs , and you are right .
VVT : center 90 nm
idler and tensioner : 24
Crank Center Bolt 110 nm
thanks for you help
VVT : center 90 nm
thanks for you help
- 3527 Views
Last post by gibbi42
- 1710 Views
Last post by kosh_al
- 1701 Views
Last post by petermetzger
- 1720 Views
Last post by Livens
- 7531 Views
Last post by miticavolvo
