Only Drained 90oz Of Coolant Topic is solved
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
I opened the overflow cap, jacked up the front left side of my 01XC and drained out 90oz/2.7L coolant. What went wrong? In the process, I pressed the upper hose a few times.
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- Has thanked: 2864 times
- Been thanked: 1332 times
Was the high/low reading on the expansion tank within range?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
its in the block, theres a drain on the back of the block if you need to get it all out.Oka wrote: 18 Sep 2020, 21:46 I opened the overflow cap, jacked up the front left side of my 01XC and drained out 90oz/2.7L coolant. What went wrong? In the process, I pressed the upper hose a few times.
Oka
Nope. The reading was high, because I filled the tank after replacing the thermostat and coolant temperature sensor. I was trying to bleed out some possible air, but the tank level was still high as I poured it in initially, so, I drained the coolant to refill the coolant the 'right' way.
Thanks.
Oka
Oh ok, and nice to know.jonesg wrote: 18 Sep 2020, 23:26 its in the block, theres a drain on the back of the block if you need to get it all out.
To do a refill, I won't have to drain that, would I?
Thanks
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
i always used the bottom hose but then i noticed the plug on the radiator and use that, ive never used the drain on the left side (back) of the engine. i get around 5litres out but theres always abit left in the block..i think you have a blockage
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- Has thanked: 1611 times
- Been thanked: 4075 times
You should get at least 4 liters of coolant if you just open the radiator petcock or pull off the lower radiator hose. Something is wrong if it’s a lot less than that, you are short About one liter.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Lots of people swear by citric acid flushes. Citric acid is a common/readily available food chemical.
Were cooling system flushes (citric acid flushes to be specific) more commonly done, A larger purchase split among members (the old "group buy") could make sense. And yes, I'm that cheap.
Do a clear water rinse and see what you get.
Where on the left side (back) of the engine is the block drain? Is it designed to be usable or is it a seized, rusted mess?
Rear drain , technically right side of the engine, is on the water pipe
It’s a high quality brass fitting on the steel pipe. I have not had trouble releasing it cleanly
- 2235 Views
Last post by alschnertz
- 2614 Views
Last post by contented
- 1161 Views
Last post by BEJinFbk
- 1272 Views
Last post by oragex
- 37 Replies
- 10487 Views
