My 2004 S80 driver's window will not raise the last 1" and I suspect a broken sliding clip and old grease.
However, I've had some scary experiences with pulling Volvo electrical connections, getting trouble codes after reconnecting and wondering if I broke or de-programmed something. Since I'll probably be disconnecting the door speaker, the window switch, and maybe playing with a partially disconnected window switch, should I disconnect the battery before tearing into the door?
Thanks!
Disconnect Battery to fix power window?
lincolnshibuya
- Year and Model: 2001 s80
- Been thanked: 3 times
shouldn't be an issue, you need the switches connected and have power anyway to diagnose and fix the issue. Access to the sliders to grease them is impossible without powering it to move up and down.
- 1711 Views
- 15 Replies
- 2436 Views
Last post by MrAl
- 4042 Views
- 16946 Views
- 2618 Views
Last post by MadeInJapan
