OBD2 reader for less than $100
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
Heh guys;
I know that several of you have recommended the code reader that is attached here below but when checking the price it goes for around $145.00. All I need to do right now is clear the SRS air bag warning on my dash so I can get my car thru state inspection.
Does anyone know of another reader that works specific to our Volvo's for say less than $100.00?
iCarsoft_Reader.pptx
(123.65 KiB) Downloaded 160 times
Has thanked: 1609 times
Been thanked: 4063 times
There are lots of $20 OBD solutions but SRS IS not an OBD standard function.
You need the $150 version of most Product lines to get the SRS clear function.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Check out Autophix ES610. It fixed my SRS on 2001 V70 T5.
Mr. Detail
Funny you would mention that volvolugnut, look what I found and for under $100.
https://www.amazon.com/AUTOPHIX-ES610-S ... 4UOWU?th=1
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Probably clear it with my VIDA. If you're willing to drive to NW NJ, we can give it a try.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Mr. Detail wrote: 08 Oct 2020, 13:46 Funny you would mention that volvolugnut, look what I found and for under $100.
It got cheaper. About $150 a couple years ago when I bought mine. The menu is a little clunky, but it worked.
donoscituate
Year and Model: v70 1999, 2005 v70
Post by donoscituate »
don't know if this is gospel, was just looking at replace a radio on a 2005 V70xc and saw this "
Note. You will need to disconnect the battery while you work on the radio console, and to be sure to turn the ignition switch to position 2 prior to reconnecting the battery, or you will need VIDA or the dealer to reset the airbag light.
If this tip is true someone put this in a must do for any time you would disconnect a battery or a visit to a dealer may be in order
Mr. Detail
donoscituate;
I believe that it is true because the only reason I now have the SRS warning message is because I needed to have my DIM (Dash Integration Module) repaired and pulled it before doing this.
Mr. Detail
EShowell, thanks for the offer. Not sure if I can get away this weekend for a try.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
You know it's chinese when it's spelled Vol-vo. Having said that, this looks to be a very low end product. Reading the comments off Amazon, people had trouble installing the software and getting the thing to connect with the car. So be prepared for a certain amount of frustration. I do have a more expensive one and can tell that one too came with good frustration when trying to set the thing up, and it also freezes when I scan all codes at once.
