Just had the steering column rebuilt.
The throttle was replaced/cleaned the day before as well.
There is now a wooshing/whistling sound on heavy acceleration. It disappears when you let go of the accelerator. The same sound does not occur whilst revving in neutral. There is also no sound when accelerating slowly.
Any ideas? I didn't think the car had Turbo though maybe that's the sound but I've never heard it before.
A split pipe maybe?
Woosh / whistle on heavy acceleration
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There is a big rubber boot where the steering column goes into the floor. It has two layers, make sure it's firmly secured to the floor with a large metal clip. Otherwise, if the hissing starts all of a sudden at high revs and it's rather loud, it may be a crack in the flexible downpipe but may be other things as well
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Which engine do you have in your V70?
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Has thanked: 1611 times
- Been thanked: 4075 times
Indeed. If the steering boot is loose, you will hear lots of new engine sounds you did not hear before. And the ‘T’ is right near the boot....
