98 S70 T5 -- Knock sensor location
mar601
Year and Model: 1998
Has thanked: 34 times
Been thanked: 5 times
Post by mar601 »
I'm having my timing belt and water pump replaced and happen to have a new knock sensor, although the car doesn't need it. Just wondering if replacing the timing belt will make it easy/easier? a cinch? to have them put on the knock sensor while they're at it. Don't really want much additional labor cost for doing it. -- THANK YOU
woodycaldercloggs
Year and Model: v70 1998
Has thanked: 23 times
Post by woodycaldercloggs »
THe knock sensor is in the middle front of the engine.
You need to remove quite a lot of stuff to get access. - doable but not a cinch
mar601
Post by mar601 »
Ok thanks very much -- I'll just pass on it.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Yeah, timing work doesn't help at all for access to knock sensors. Timing is on what is technically called the front of the engine i.e. near the passenger wheel, knock sensors are under the intake manifold on what is called the right side.
Has thanked: 1609 times
Been thanked: 4064 times
erikv11 wrote: 09 Oct 2020, 13:14 Yeah, timing work doesn't help at all for access to knock sensors. Timing is on what is technically called the front of the engine i.e. near the passenger wheel, knock sensors are under the intake manifold on what is called the right side.
Right side looking front to back of engine, from crank pulley to flywheel
