I have a 1998 Volvo v70 and always have to slam the tailgate to close it completely.
I can never just click close it.
Does anyone know if that is caused by the floor latch being positioned too far back?
Would shifting it a few mm forward solve the problem?
Slamming Tailgate
woodycaldercloggs
- Year and Model: v70 1998
- Has thanked: 23 times
- Has thanked: 312 times
- Been thanked: 818 times
You are on the right track to look at the position of the floor latch. I would loosen it up then figure out the best position then tighten it back up. My point being, sometimes it needs to move in the opposite direction from what you might expect. Also check the little rubber bumpers out at the sides, see if they are intact and not protruding etc.
I would loosen it up then figure out the best position then tighten it back up. Sometimes the latch needs to move in the opposite direction from what you might expect. Also check the little rubber bumpers located out at the sides, see if they are intact and not protruding etc.
Ummm ok I think you get my point by now
- Has thanked: 987 times
- Been thanked: 1078 times
If your secondary catch has a rubber or plastic cushion, check that it is not damaged. With extended use these cushions can cause latching problems. Adjustment can help, but may not solve if the cushions are bad.
bronco
- Year and Model: 1998 V70
- Has thanked: 49 times
- Been thanked: 24 times
What I tell you THREE times (four) is true , really really trueerikv11 wrote: 09 Oct 2020, 13:30 You are on the right track to look at the position of the floor latch.
- Has thanked: 1613 times
- Been thanked: 4078 times
Tell us what you really, really, really, really think
Volvo,Spice
Volvo,Spice
Today I found I have the tailgate won't latch problem. It may be a contagion. If you read this, wear a mask while opening your tailgate for the next 10 days.
- 2767 Views
- 2988 Views
Last post by 321lor
- 2803 Views
- 1218 Views
Last post by sergio
- 5306 Views
Last post by pierremcalpine
