my v70 2001 2.4 n/a is having an issue I think with the etm however it's just been re-manufactured and continues to do this when the engine is cold before starting (see video).
Once the engine starts I have no cruise control. Although diag comp. shows button is working (it appears disabled) car runs lumpy and rich and once warm a restart cures all issues and it runs perfectly 9/10 times.
Code set for " internal fault ( no signal) etm"
I've got her booked into volvo for etm reload on Thursday.
But I feel that this issue seems more mechanical as opposed to electronic due to the fact it cures when hot? Please if anyone has experienced this before and cured it can you help!
Thankyou
ETM problem - V70 2001 2.4 NA Topic is solved
ashleyg82v702001
- Year and Model: 2001 v70
- Been thanked: 4 times
MOV_1632_000.mov- (19.43 MiB) Downloaded 90 times
Reason: Edited Subject. Please no 'help' in Subjects.
ashleyg82v702001
I did have a look when I stripped it to send it away.. But perhaps I need to revisit that and have another long hard look
ashleyg82v702001
It was a failed etm, rebuild was a failure... Had to go main dealer to get new and etm reload/calibration Fortunately got my money back from remanufacturer.
Bye bye £500.. On a plus car is now running beautifully
How many miles were on the original one?
ashleyg82v702001
Only 57,500 surprisingly..
That’s a really early failure. I don’t like data that doesn’t support my theories so I’ll try to ignore this. That seems to be our current governments approach to Covid
ashleyg82v702001
Yes it is early, my thoughts are age related failure rather than wear (dry solder joint?) 19 years supposedly.. Obviously I don't know if the previous owner had replaced with a breaker part so may have been more used?
There is a date code on the throttle body , something like YY W NN. The w stands for week of manufacture NN in year YY
ashleyg82v702001
Yes my old throttle body had a Nov 2000 build date.
Which would probably coincide with the car build date
- 4720 Views
Last post by firstv70volvo
- 4962 Views
Last post by antonevane
- 15 Replies
- 6767 Views
- 4508 Views
Last post by ajwsurfer
- 1202 Views
Last post by bollin
