I have an 1996 850 R looking to replace the wire looms (all of them). Has anyone replaced these recently ? I don't want to guess the sizes.
Wire Loom Replacement
- Has thanked: 1614 times
- Been thanked: 4078 times
Check
https://www.volvopartswebstore.com
To see if they are available as new parts, otherwise it’s a junkyard time!
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
All the junkyard ones will be old and crunchy. You may need to build them yourself.
- Has thanked: 312 times
- Been thanked: 818 times
Yeah definitely can not go junkyard on wire looms, you won't even be able to collect them they will crumble in your hands. I have replaced some but I did it by getting several sizes then I have it on hand and use as needed. I'd be interested to know what it takes for a complete job, too.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Time to buy bulk wire and build a wire loom.
Oh I thought OP was just talking about this stuff
https://www.amazon.com/GS-Power-Split-L ... 922&sr=8-3
- Has thanked: 987 times
- Been thanked: 1078 times
If you are looking for wire loom, then try to get high temperature rated. 275 to 300 F rating is better. The cheap wire loom will not last long on top of engine.
IPD has high temperature rated in the small sizes.
- 631 Views
Last post by 454cid
- 334 Views
Last post by S60T5SE
- 1170 Views
- 1251 Views
Last post by zanzabar
- 2830 Views
Last post by Marauder 1
