Changing CAN bus Ohm Readings
I'm trying to diagnose faulty high speed and low speed CAN Bus circuits. I tried to tackle the low speed first, so I disconnected the UEM at the A pillar junction and took a reading of the UEM and got 118Ohms, then took a reading of the rest of the circuit and got 230 Ohms, a minute later I reread to confirm and I got 106Ohms, switched leads, 230, put a new battery in the multimeter, got 230, waited a minute got 106 and on and on. As much as I jiggle the wires nothing changes the ohm reading besides disconnecting, waiting, then reconnecting. I tried with the UEM connected and the REM disconnected and got the same readings. They switch between those two seemingly randomly. Any ideas? Thanks for any suggestions you could throw my way.
- Been thanked: 4064 times
Are you measuring resistance on a live circuit? That won’t be meaningful
- 3650 Views
Last post by don98s90
- 1337 Views
Last post by MarcM
- 1774 Views
Last post by brunotata15
- 4647 Views
Last post by ChrisatXeMODeX
- 1509 Views
Last post by drjurman
