ECT failure?
dneu
Year and Model: 2004 V70R
Post by dneu »
On my 2004 V70 R a coolant temperature gauge does not work anymore. I have replaced ECT sensor and checked wires in a connector all looks good. After deleting the error code it takes about 5 minutes driving and ECT failure is back. Any advice where I should look?
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
check the wiring diagram and get to work with your multi-meter checking for continuity. Try removing the gauge from the DIM you should be seeing continuity or voltages there. At worst it could be a ECM issue but i doubt it, i put money on it being a poor connection or the gauge.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
dneu wrote: 16 Oct 2020, 14:24 On my 2004 V70 R a coolant temperature gauge does not work anymore. I have replaced ECT sensor and checked wires in a connector all looks good. After deleting the error code it takes about 5 minutes driving and ECT failure is back. Any advice where I should look?
recent posts prove aftermkt sensor not dependable, a brand new sensor was no good.
Genuine volvo sensor fixed the dead guage.
