Rear wiper nozzle direction?
qwertyjjj
Year and Model: V70 2004
Has thanked: 1 time
Post by qwertyjjj »
The rear wiper spray nozzle seems to be pointing down instead of up (probably got iced up in the winter).
How can I reposition it?
Also, my current blade starting position seems to be on the right whereas in some videos I see it on the left - is there a way to reset the starting position with the ignition key?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
The nozzle issue is here. You need the tie rod puller ($10 at local part store) to help pull the wiper arm off:
viewtopic.php?t=92815
The rear wiper arm resting position is LEFT. Idk how yours ended up on the right side, maybe some gurus will chime in later.
qwertyjjj
Has thanked: 1 time
Post by qwertyjjj »
I replaced the motor a couple years ago and in the process somehow got it to park on the right.
So, obviously there's a way to reset it but don't know how.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Some of the rear wipers park to the right and some to the left. I don’t know what years went what direction. If you have the wrong wiper for your particular car then the nozzle deflector will spray downward rather than up onto the glass.
Post by cn90 »
Interesting as I always thought the P2 V70 rear wiper always rest on the LEFT side.
If you do a google image search using key words such as "2003 Volvo V70 tailgate...", you will see images showing BOTH R and L parking position.
Go figure...
Post by cn90 »
Now I am curious in terms of fluid source...
- Is it from the top squirting downward...or...
- From the wiper motor spindle squirting up?
chrism
Post by chrism »
cn90 wrote: 18 Oct 2020, 10:35 Now I am curious in terms of fluid source...
On my 2003 V70 Base model it's from the wiper motor spindle squirting up.
qwertyjjj
Has thanked: 1 time
Post by qwertyjjj »
Wiper motor spraying up.
I'm almost certain it used to be on the left until I changed the motor. Maybe the positioning is based on the replacement motor and not the computer?
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Been thanked: 5 times
Post by Herb Goltz »
I have 2004 and 2006 XC-70s, and both park on the right.
2012 s60 t5
2006 XC70
2004 XC70
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
interesting .. post, both of my cars 2002 and 2002 park on the left. Simply removing the arm and parking it on the left will not work as it will try to wipe your number/licence plate . As they say a picture would tell a thousand words.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
