Is it possible to remove rear subframe on 2000 Volvo V70xc without a lift?
Richard99
Year and Model: 2000 V70XC
Has thanked: 26 times
Been thanked: 23 times
Post by Richard99 »
Hi,
Wondering if anyone has removed the rear subframe on a 98-00 Volvo V70xc without a fancy shop lift? Not sure if there is enough clearance created from normal jack stands to get it out of there.
Eric
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
Has thanked: 1613 times
Been thanked: 4078 times
Extensive posts from Neil on this, stay tuned
Richard99
Post by Richard99 »
abscate wrote: 17 Oct 2020, 19:07 Extensive posts from Neil on this, stay tuned
Haha. Neil is the man! Eh?
Eric
2000 Volvo V70XC
Richard99
Post by Richard99 »
V70xc guru
Eric
2000 Volvo V70XC
Short version, once you get the main bolts out it is quite easy to drop, but it is common that the bolts get seized in the Aluminum subframe in wet climates
Richard99
Post by Richard99 »
abscate wrote: 18 Oct 2020, 04:54 Short version, once you get the main bolts out it is quite easy to drop, but it is common that the bolts get seized in the Aluminum subframe in wet climates
I see. My main concern is whether I'll have enough clearance to slide it out from under the car, and the difficulty of bolting it back up to the car - lining everything up right.
Eric
2000 Volvo V70XC
Richard99 wrote: 18 Oct 2020, 09:55
I’ll put mine on a pallet with castors when I do my drop and replace On my S70’AWD
Has thanked: 2215 times
Been thanked: 1853 times
I did it with a pair of long axle stands I own. I placed them near the rocker panel pinch weld on a piece of wood between it and the floor to spread the load.
I used a floor jack under the rear diff plate to pull the whole frame out. I placed a piece of wood on the floor jack to spread the load and make it a little more steady on the jack.
I need to see if I can find my 'R' sub-frame thread.
This is the thread I'm was talking about. On page 6 of the thread there is a picture of the rear subframe mounting area and on the RHS of the picture you can see the axle stand the car is sitting on.
viewtopic.php?f=1&t=69287&hilit=V70R+sub+frame&start=50
Richard99
Post by Richard99 »
scot850 wrote: 18 Oct 2020, 20:38 This is the thread I'm was talking about. On page 6 of the thread there is a picture of the rear subframe mounting area and on the RHS of the picture you can see the axle stand the car is sitting on.
https://www.matthewsvolvosite.com/forum ... e&start=50
Hi Neil. I see where you start to mention the issue of disconnecting the hard brake lines without letting all the fluid out. How did you accomplish this? Also, for the parking brake cables did you just cut those and replace them later with new ones?
Thanks,
Eric
Eric
2000 Volvo V70XC
