Won't start - No fuel to the cylinders
mr.benedikt
Year and Model: Volvo 850 1995
Post by mr.benedikt »
Hi
I have a 850 1995 2.0 20v.
It had some trouble running and now it won't start.
The fuel pump runs and there is fuel in the rail (comes out when pushing in the Schrader valve), but there is no fuel comming from the fuel injectors (I pulled them out and started the car).
Does anyone have an idea what can be wrong? Is there a relay for the injectors?
Best,
Benedikt
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Normal replies to this sort of issue would include the following:
Use a jumper on relay 103 (fuel pump relay) - to rule out bad relay.
Test fuel pressure using a gauge - to rule out bad/weak pump.
Note: When my fuel pump relay failed, I had pressure at the rail but car would not stop. It transpired the relay was an intermittent failure, so occasionally fuel would be pumped up to the rail - which initially led me to assume relay was good.
mr.benedikt
Thanks.
There was pressure at the rail, at least the prepump before starting, I put a bicycle shock pump on the valve :) and it measured over 40.
I will try to measure the pressure when it is starting.
Has thanked: 2210 times
Been thanked: 1852 times
Regular fuel pressure for your year is around 43 psi.
Hopefully issue is simple.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Main fuel injection relay is the grey one on cooling fan shroud.
Fuel pump relay operates just fuel pump.
Check fuses first.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
scot850 wrote: 20 Oct 2020, 13:50 Regular fuel pressure for your year is around 43 psi.
YES...but....
For cars with FPR at fuel rail which is vacuum controlled:
-1st prime without starting the car 43.5psi
-at idle around 35psi
-at WOT in high rpms...again 43.5psi
M4.4 cars with FPR at the back near the fuel filter,fuel pressure is maintained constantly at 43.5psi.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Pressure in the fuel rail but injectors not pumping fuel. I would be looking at the 12V supply for the injectors, which is the Green wire that goes to each of the five injectors.
On fuel injectors and Coil packs: The high side (+) is common rather then the low side (-) or common ground.
Active
Past
