Do you agree that your Volvo could use some SPICE? Some modern touches perhaps? WELL NOW, just like the EDC video I released, this video may give you ideas! LEDs, USBs? Yes please! LOL! Presenting my modern 1996 Volvo.
Mod mods (modernization modifications) for your car
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Well you certainly won't have any issues finding stuff in the dark.
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
Why not just replace the halogen bulbs inthe holders with LEDs? Then you get your brighter whiter light without the tacky (subjectively) strips with cables floating around everywhere.
USBs are solved with a cigarette lighter adapter that almost looks OE. Rear USBs isn't a bad idea and looks like a fairly tidy installation.
I also like the idea of under-bonnet lighting (preferably switched by the bonnet lever), it would be more convenient than the head torch I currently use.
Personally I have upgraded all the interior halogens to warm white LEDs, have a twin USB adaptor in the front cigarette lighter, auto-up/down on the front windows, a USB/mp3/bluetooth adapter plugged into the CD port of ky headunit, and LEDs on the reverse lights. Reversing down unlit single carriageway Welsh roads at night necessitates this.
I am toying with the idea of upgrading the interior speakers (maintaining the same size), and now with a under-bonnet LED.
yanga001
- Year and Model: 98/99/00 v/s70โs
- Has thanked: 62 times
- Been thanked: 115 times
My new v70 came with a kenwood head unit which solved 75% of my requirements. Put a small compass in the car (i am directionless) and added a 150W inverter to it. Only other creature comfort was swapping the driver seat to a powered version so i could actually adjust the seat on the road.
Lighting wise, used a projector retrofit with many hours of testing to ensure im not blinding other drivers.
2008 S60 2.5T Auto (Sold)
- CIK7
Thank you for the specified feedback!Cookeh wrote: 22 Oct 2020, 04:27 Why not just replace the halogen bulbs inthe holders with LEDs? Then you get your brighter whiter light without the tacky (subjectively) strips with cables floating around everywhere.
What do you mean 'holders'?
Yes I think the wires add just a tidbit of tackiness, it doesn't look as clean. I don't think the LED bulbs would provide enough coverage though. This way I have a lot more coverage of the front, aisle, and back.
I use to use a 4 port charger that had 1 QC 3.0 port but I didnt like the risk of shorting the socket and starting a fire. I don't know what you mean by USB adapter. I think these usb sockets have a clean look though. I really like the on/off touch feature.
When I would get under the hood at night there are 2 flashlight types I have. The cheap magnetic ones with the plastic hook and the Cree torch lights with green rubber button. Either I would hold the flashlight hook in my mouth, hook it on the hood latch or hold the end of the Cree flashlight in my mouth. I'd be drooling and stressing my mouth muscles.
I can not stand those bluetooth mp3 adapters. They are bad imo. In my XC, plugging in the 12v bt adapter would start an unending slight squeal, so even with the best music there would be a squeal.
Yes as I said before, the 960 sound system is beyond amazing. Its to the degree of a modern aftermarket system with quality highs and a nice subwoofer in it. It's that good.
Under-hood LEDs? GO FOR IT! You might find an easier way to install but I did a completely custom job on it, took me about...2-3 hours from taping them on and wiring to sticking them on and hooking up the power and switch. By the way, I JUST updated my post with a pic of the switch. I used a step bit to drill in the factory switch blank for the power switch. I'm gonna check if I can put a factory one in.
- CIK7
Yes as I've told everybody else, my stereo is extremely high quality, like the sound of a high end aftermarket system with awesome highs and a powerful subwoofer.yanga001 wrote: 22 Oct 2020, 07:38 My new v70 came with a kenwood head unit which solved 75% of my requirements. Put a small compass in the car (i am directionless) and added a 150W inverter to it. Only other creature comfort was swapping the driver seat to a powered version so i could actually adjust the seat on the road.
I need to find a decent inverter because I'm going to be installing a PA (public announcement) system within the next month. What brand did you use?
You seem to like those NA s70 models. Since I got my XC, I have wanted to go from a power seat to a manual seat. Is your manual driver seat cloth or leather?
- Cookeh
I just mean the OE lights, basically, so what the normal halogens go in. When going for LED bulbs I also wondered how much of a difference it would make, but it was significant enough for me to actually buy lower wattage-rated LEDs as they were too bright! Cable wise, a lot of it could probably be routed behind trims, with enough time spent.CIK7 wrote: 22 Oct 2020, 09:14
What do you mean 'holders'? Yes I think the wires add just a tidbit of tackiness, it doesn't look as clean. I don't think the LED bulbs would provide enough coverage though. This way I have a lot more coverage of the front, aisle, and back.
I mean this sort of thing. For the rear what you have done is a good approach, for sure.CIK7 wrote: 22 Oct 2020, 09:14I use to use a 4 port charger that had 1 QC 3.0 port but I didnt like the risk of shorting the socket and starting a fire. I don't know what you mean by USB adapter. I think these usb sockets have a clean look though. I really like the on/off touch feature.
Yep, that certainly sounds familiar...! Luckily only happened once though.CIK7 wrote: 22 Oct 2020, 09:14When I would get under the hood at night there are 2 flashlight types I have. The cheap magnetic ones with the plastic hook and the Cree torch lights with green rubber button. Either I would hold the flashlight hook in my mouth, hook it on the hood latch or hold the end of the Cree flashlight in my mouth. I'd be drooling and stressing my mouth muscles.
I too am somewhat of an audiophile. I don't mean the one that plugs into the cigarette lighter and uses FM radio for transmission - they are, as you say, garbage. I have a usb/bluetooth/mp3 adapter that takes the place of the CD multichanger, and plugs into the same port.CIK7 wrote: 22 Oct 2020, 09:14I can not stand those bluetooth mp3 adapters. They are bad imo. In my XC, plugging in the 12v bt adapter would start an unending slight squeal, so even with the best music there would be a squeal.
I think the 850 ones were very good new. Now, however, I suspect both magnets and cones have degraded over time.CIK7 wrote: 22 Oct 2020, 09:14Yes as I said before, the 960 sound system is beyond amazing. Its to the degree of a modern aftermarket system with quality highs and a nice subwoofer in it. It's that good.
Thanks for that, definitely makes sense having them switched. Im toying with the idea of buying a foglight switch and printing a new sticker (to cover the fog light symbol) - for the ultimate OE look.CIK7 wrote: 22 Oct 2020, 09:14Under-hood LEDs? GO FOR IT! You might find an easier way to install but I did a completely custom job on it, took me about...2-3 hours from taping them on and wiring to sticking them on and hooking up the power and switch. By the way, I JUST updated my post with a pic of the switch. I used a step bit to drill in the factory switch blank for the power switch. I'm gonna check if I can put a factory one in.
- CIK7
Back when I bought 2 Anker Roav dashcams, each came with an adapter identical to that.
Can you please show me what you are talking about? The port and adapter? Oh are you talking about a GROM? I saw a pic of a WEPยฎA device connected on a P2 car radio. Similar to GROM but idk where those devices connect to.Cookeh wrote: 22 Oct 2020, 10:48 I too am somewhat of an audiophile. I don't mean the one that plugs into the cigarette lighter and uses FM radio for transmission - they are, as you say, garbage. I have a usb/bluetooth/mp3 adapter that takes the place of the CD multichanger, and plugs into the same port.
Interesting! Maybe Dolby slacked on quality/durability for the P80s?!Cookeh wrote: 22 Oct 2020, 10:48 I think the 850 ones were very good new. Now, however, I suspect both magnets and cones have degraded over time.
I looked through my XC part bin and unfortunately cant find a 3 wired switch. The XC switches are gray anyway, while the 960 and Chinese switches are black. I'm keeping the black switches.Cookeh wrote: 22 Oct 2020, 10:48 Thanks for that, definitely makes sense having them switched. Im toying with the idea of buying a foglight switch and printing a new sticker (to cover the fog light symbol) - for the ultimate OE look.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
You're missing the "[" at in front of the tag.CIK7 wrote: 22 Oct 2020, 18:37
I did my best to put in quotes, hope it works. Edit: nope the quoting didn't work. I'm sorry. I've tried it before and failed; it's difficult.
- 1140 Views
Last post by CIK7
- 28 Replies
- 9790 Views
Last post by j-dawg
- 1336 Views
Last post by BlackBart
- 1194 Views
Last post by Ozark Lee
- 3271 Views
Last post by a3inverter
