2005 Volvo V70 2.5T AWD estate/wagon
My dash keeps flashing up "panne d'ampoule feu de position" after I hooked up mate's trailer ..... car originally sold in Quebec and no I don't speak French. And yes I googled it but all results are in French and I don't understand them.
Seems to be saying "position light" out but I have looked all around the car and everything looks good (no trailer plugged in now). It flashes on and off all the time and with no specific pattern etc..
Any pointers would be awesome.
Cheers.
Dash indicator that I can't read ......
- yagger
- Year and Model: V60 2016
- Has thanked: 6 times
- Been thanked: 39 times
Maybe better to reprogram DIM to English?
Volvo electronic expert
Online Data Transferring Service for Volvo modules
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
I have a Swedish speaking DIM, i'll swap ya French is much easier to understand
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- RickHaleParker
- Been thanked: 978 times
I would be looking for Wire Chafing on his trailer. You will get that message if a light circuit shorts to ground. It is intermittent, which indicates a harness moving, which in turn can cause chafing ....
Active
Past
Past
When it starts texting
Non, he ne regrette rien
You know you have real problems
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
That would be indeed faulty position light bulb, there's two of these very fragile bulbs in each tail light, possible the small tungsten has cracked on one and still makes intermittent contact. May also pull the bulb and inspect the socket for corrosion.Duncx wrote: 31 Oct 2020, 13:20
As mentioned, it's a good idea to at least write down most common important messages in french, have the paper with you
Mostly messages with charge batterie or systeme electrique (battery charge, usually faulty alternator regulator), huile moteur (engine oil), niveau bas liquide refroidissement moteur (low engine coolant level), arreter (stop), anti patinage (anti-skid), freins (brakes)
I found a nice owner's manual, it has a few messages at page 43, unfortunately it's not all of them https://az685612.vo.msecnd.net/pdfs/28e ... tp8147.pdf
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
"No, he doesn't regret anything"....? Is this an example of literal translations and colloquailisms colliding?
It’s an Edith Piaf classic. You’ve heard it in many high end ads for expensive stuff on TV
- RickHaleParker
I found the one that matches his V70.oragex wrote: 01 Nov 2020, 06:43 I found a nice owner's manual, it has a few messages at page 43, unfortunately it's not all of them https://az685612.vo.msecnd.net/pdfs/28e ... tp8147.pdf
https://az685612.vo.msecnd.net/pdfs/6b0 ... tp7552.pdf
Active
Past
Past
- 739 Views
Last post by Jkenny
- 869 Views
- 1076 Views
Last post by Ozark Lee
- 995 Views
Last post by davidcschulte
- 2156 Views
Last post by esl_97_850_T5
