V70 auto trans in a 850
chrillew
Year and Model: volvo 850 T-5R 1995
Been thanked: 2 times
Post by chrillew »
Hey wondering if a v70 aw50-42le fits in a volvo 850 1995 t-5r.
Im asking because i dont seem to be able to find a trans from a 850 t5 in Sweden. But if i can get a trans from a v70 turbo to work in my car its easier to find.
Possible?
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
The ones out of a '97 or '98 V70 should fit. They are the 4 speeds. You might need the Transmission control module out of the donor car though. And I think there was something different with the speed pickup sensor up to 95 or 96 and the later ones.
As far as I know the 5 speeds won't fit.
1996 855 R,
2010 V70 D5,
chrillew
Post by chrillew »
Okey Thanks! So only need to get speed signal from ABS then i suppose? Hope Someone could chime in if i need The tcu aswell. They seem identical same pnp switch. Same rpm sensor on The top. But not The same speed sensor on The driveshaft what i can see externally.
