New problem, tape cassette won't stay in HU-613 player ?
shodanx
Year and Model: xc70 2001
Post by shodanx »
Hi,
I've been using a cassette to 3.5mm headphone input adapter for about 2 years in my XC70 2001.
It has been largely trouble free in that period. A few times when I put the cassette it, it would do Side A / B / A then eject routine but usually on the second or third try it would work and stay in without issue for months.
However, about a month ago, I put the cassette in and it checked both sides then ejected the tape.
I tried dozens of times and it just won' t stay in. I can jam it in (keep my finger in) but as soon as I let go, it comes out again.
Is there a way to overcome this without taking out the head unit ?
thanks
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Has thanked: 7 times
Been thanked: 5 times
Post by Herb Goltz »
When this happened with the SC-816 that was in my old 2000 V70, the drive belt for the cassette mechanism was broken (I had been using a cassette adapter to play mp3s). I switched to a bluetooth hands-free adapter, which is much more convenient.
2012 s60 t5
2006 XC70
2004 XC70
Has thanked: 1610 times
Been thanked: 4068 times
Try removing the tape and just using a blank cassette. I, too, have gone Bluetooth FM for this
shodanx
Post by shodanx »
Thanks, I will eventually try to remove the radio and see if I can repair it.
In the mean time, which bluetooth FM transmitter do you recommend ? I have tried half a dozen and they all end up with static no matter what channel I use and the audio quality is not as good as wired.
Herb Goltz
I have this one in both of my XC70's:
https://www.amazon.ca/VicTsing-Transmit ... 3381340011
No static problems unless there is a strong radio station at the transmitter frequency, more of an issue when driving in downtown Toronto. These gadgets pacified my teenagers, who were disappointed that the "new" cars didn't come with at least aux jacks!
2012 s60 t5
2006 XC70
2004 XC70
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Don't forget to disconnect the car battery. These radios should be cheap off Ebay, may try finding one of the same 2001 year as yours. Also a few videos on Youtube how to remove it, all it takes is a T25 philips screw driver (not sure if a torx socket will fit in there)
