It came with little clips as well - I just want to know where everything connects, visibly, under the hood of the car before digging into it Saturday morning.TCV Hose Replacement - Routing
moncureww
- Has thanked: 3 times
Is there an exploded diagram of the TCV hose layout for a 2006 s60 2.5T, and where everything connects? I am replacing my TCV this weekend, and plan on replacing the TCV hoses at the same time - I have this kit from IPD:
It came with little clips as well - I just want to know where everything connects, visibly, under the hood of the car before digging into it Saturday morning.- abscate
Take the time to understand function , not just “ hose by number”
The TCV is a two way valve which routes pressure to either the wastegate ( yellow) actuator to turn on boost or it routes it to the intake snorkel ( blue) to dump it if boost isn’t required.
The pressure comes from the turbo compressor housing ( red)
The OEM tcv have dots of the right colour to help guide what goes on what , too. See if those are visible before you start
There should be a sticker under the hood documenting this but the blue hose is notoriously poorly labeled on these onearlier models. It goes down to the snorkel low near the turbo intake
moncureww
Thanks. I've been reading how this turbo system functions, and looking to make sure the turbo, intake, and vacuum system is in tip-top shape before I upgrade the downpipe and exhaust this spring. I'm getting an ipd tune next year after I get everything to stage 0 and drive it a few thousand more miles.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
When I did this (with the same ipd hose kit), I removed the air filter box and intake plumbing, and the big filter-box-to-turbo pipe. Enough things out of the way so you can get your head and a light back there. I carefully replaced one at a time, using the same routing through any brackets and clips. Cut to fit with enough slack to work with. The existing squeeze clamps were a bit too big for the new silicon hose, so use the new ones. I had some in my stash that were even tighter. I like a very long reach needle nose or square jaw pliers on those.
moncureww
Thank
Thanks for the explanation - I think I'll do the same. I went ahead and got a new boost pressure sensor at the same time - when i get my tune and exhaust this spring I want to make sure everything is in tip-top shape on the intake side well in advance, and take it weekend by weekend. I'll be removing and replacing all the plumbing I can to make things accessible. Do you think it would be worthwhile to replace all the rubber hose I can with silicone while I'm doing all this? Is there anything else worth handling preventatively while I'm in there? I've already replaced the PCV system and done a complete tune up on the engine, and replaced the OTE turbo couplers with IPD silicone...BlackBart wrote: 11 Nov 2020, 19:50 When I did this (with the same ipd hose kit), I removed the air filter box and intake plumbing, and the big filter-box-to-turbo pipe. Enough things out of the way so you can get your head and a light back there. I carefully replaced one at a time, using the same routing through any brackets and clips. Cut to fit with enough slack to work with. The existing squeeze clamps were a bit too big for the new silicon hose, so use the new ones. I had some in my stash that were even tighter. I like a very long reach needle nose or square jaw pliers on those.
- 2455 Views
Last post by JimBee
- 5227 Views
Last post by Salomons Driveway
- 2067 Views
Last post by 93Regina
- 818 Views
Last post by packetfire
- 737 Views
