where is the Oil Pressure Sensor in my 1991 240 4cyl
Amateurthinker
Year and Model: 1991 240
Post by Amateurthinker »
I have a problem with a flickering oil light at low engine speeds and wanted to change the sensor... but didn't know where it was.
I just had some new alternator belts put on, and wondered if there were any oil pressure sender wires, that could have been disrupted.
Any ideas would be helpful...
Where is that sensor
Thanks
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Unless it was moved on later year 240 4 cylinders. I think you will find it back of the oil filter on the right side of the block (driver position point of view). I think it will have a spade connection and is easy to knock loose.
