V70 2012 air con clutch not engaging.
MiddoV70
Year and Model: 2012 V70 D5 Nav
Post by MiddoV70 »
Hi everyone ...
has anyone had any issues with there air conditioning? On 2012 V70
So far I've had refrigerant check regass , compressor changed and clutch gap tolerances checked as the clutch is not engaging , rad fan control module changed along with wiring check and Vida is only throwing a fault up for the rad control module showing open circuit hence why it was changed . Even the light comes on the switch.
Has anyone had any other instances or aware of a fix . Thanks for any input you may have πŸ‘
