I found rectangular caps above my spark plugs; and the wires leading in do not look like traditional spark plug wires. Is this a form of electronic ignition...and, if so, how do I safely remove them to provide access to remove the plugs?
djmeo
2000 v70 xc spark plug rectangular tops-electronic spark?
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Coil on plug ignition...
Here is an example of what I believe you are seeing...
https://www.fcpeuro.com/products/volvo- ... SlEALw_wcB
Should be a single torx bolt on each holding it in. Usually no reason to remove them unless you're changing plugs.
- Been thanked: 4064 times
I think stock coil hold down bolts are m6 with a10mm hex head.
Those bolts are important and need to be clean as they complete the coil ground , too.
Label both the coils and the wire with number 1-5, starting with number 1 at the far passenger side, right side of Dar, being number 1. You can mess up the order in which case your car won’t start
- 3010 Views
Last post by Roger_850T
- 1600 Views
Last post by jimmy57
- 3878 Views
- 42 Replies
- 8747 Views
Last post by precopster
- 1784 Views
