Seat upholstery compatibility S/V70
ollebompa
Year and Model: 1998 S70 TDI
Has thanked: 1 time
Been thanked: 4 times
Post by ollebompa »
Hello,
I'm going to attempt a leather seat conversion on my 98 S70. Before I take a trip to the junkyard next week I'm trying to figure out between which years and options the seat upholstery or entire seats will be compatible. Due to the SIPS bag differences I'm pretty certain the 99 and 00 front seats will not work in my 98, but I should still be able to use the upholstery from any year when it comes to the front seats, right? Also, for the seat bottoms I believe the skins will be compatible between passenger and driver sides. This would make life easier as a good condition drivers seat is usually hard to find. My car has manual seats adjustments but I think the skins from an electric powered seat should work for manual seats after making some holes for the adjustment knobs. And finally for the back seats I'm fairly sure I'll need to find one from a S70 as the back seat of a V70 is a lot different.
Can anyone here on MVS confirm whether I'm figuring this correctly?
Thanks!
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Looks like you have seen all the same information as I have over the years...
Current Volvos:
Has thanked: 1610 times
Been thanked: 4068 times
Seat bottoms swap driver to passenger no problem..... see thread here
https://www.matthewsvolvosite.com/forum ... 85#p466785
I’ll have a nice set of new seat bottom skins for sale shortly, in light beige too, for P80
Driver passenger seat back skins swap with minor cosmetic surgeries needed for both manual/ power swaps and the side swaps. I have left over material in graphite if these are needed but usually you can harvest leather from your old crusty seat
I think S70 and V70 seats are completely different , yes. The split differently , I think? Not sure.
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
Different rear mounts and side bolsters.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
I'd imagine that the bottom of the rear seat of V and S could be interchangeable
1996 855 R,
2010 V70 D5,
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
From what I can see in the parts catalog. All the front seat skins from the P80 S/V 70 are interchangeable. They maybe be some cosmetic differences but they should interchange.
Active
Past
ollebompa
Has thanked: 1 time
Post by ollebompa »
Clemens wrote: 28 Nov 2020, 12:30 I'd imagine that the bottom of the rear seat of V and S could be interchangeable
After having a look at a V70 I can safely say that no part of the rear seat is interchangeable. The V70 seat bottom is split and also mounts differently with a hinge such that it can be folded forward to make room for the seat back to be folded to lie level with the cargo compartment. On the S70 the bottom is not split nor hinged.
The rear seat is turning out to be the difficult part to get hold of. Not too many S70s out there with full leather options...
