Replacing rear toe bolts 2011 xc90 v8
Pretribrapper
- Year and Model: 2011 C30 2.0 T5
- Has thanked: 59 times
- Been thanked: 9 times
Anyone have a clue what I need to replace specifically? I am told from alignment that I need to replace the rear toe bolts to get alignment correct as mine are bad and cannot be adjusted. I don't see a such thing as rear toe bolts. Not sure if I need eccentric bolts or something else but alignment shop was not all that helpful. Please help
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
There's a slotted bar on the back (the "stay", PN 9200217), then the adjustment is via an eccentric bolt/nut combination (PNs 986931, 31201493, 985870). See diagram in whatever Volvo reseller site comes up in your search for the first PN, will give you an idea as to how the rear suspension is laid out.
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
The rear toe arm is the lower square arm. What happens is the threads of the inner eccentric bolt (bolt to the center of the subframe) rusts and shops get scared to adjust these because it may take heat and/or damaging the bolt and nut. Some places, when replacing the bolts and nuts may add a little bit of anti-seize on the bolt threads, especially in rust prone areas. This will allow future alignments without worrying about damaging the bolt and nut.
You can view the items here, #4-6, #7 is the "toe" rod/control arm for reference: https://www.volvopartswebstore.com/show ... veLine=509
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
- 4909 Views
Last post by erikv11
- 1134 Views
Last post by sandiegoman
- 869 Views
Last post by - Pete -
- 2498 Views
- 462 Views
