2006 V70 won't unlock
fordgt
Year and Model: 2006 V70
Post by fordgt »
My wife's V70 won't unlock, either with the key fobs or the key in the driver door lock ( I can't believe there is only one mecahnical entry on this vehicle). Anyway, this just started today, put new batteries in the remotes, the battery in the back is new 3 months ago. The little red light on the dash is flashing so the battery isn't completely dead? It would seem I would have to pry open the top of the door and pull up the latch. Any other options? Thanks.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
fordgt wrote: 04 Dec 2020, 17:59 My wife's V70 won't unlock, either with the key fobs or the key in the driver door lock ( I can't believe there is only one mecahnical entry on this vehicle). Anyway, this just started today, put new batteries in the remotes, the battery in the back is new 3 months ago. The little red light on the dash is flashing so the battery isn't completely dead? It would seem I would have to pry open the top of the door and pull up the latch. Any other options? Thanks.
this should get you in at least.
fordgt
Post by fordgt »
Thanks for the video lots of good ideas, (I thought one might be a BFH) I actually have one of the kits with the bladder shown toward the end of the video. I got in, in about 10 minutes this morning. Weird though, after I got in it started right up, doors locked, unlocked with the remote. I still have to take the door panel off to figure out why it won't unlock with the key. That is purely mechanical, right?
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
There is a plastic clip that snaps around a rod. They deteriorate over time, and the driver's side door gets the most use. I'll bet it either broke or came loose. Hardest part is disassembling the door panel to get to it.
Make sure you disconnect the battery before starting, and use the correct battery reinstall procedure so you don't lose other modules and remote door lock function. You can search for those procedures in this forum.
Good luck.
