Front L wheel began to have scraping sound. Neil nailed it, it was L caliper so now both fronts have new rotors, calipers and pads. These Volvo brakes are the nicest ones I've worked on, easy to swap out.
Just before I took it off the road and ordered those parts the ABS light came on and persists still now with fresh parts. I disconnected the battery thinking it may reset, no dice. My little blue driver code reader and reset did not clear the ABS dash light. Brakes are working fine though I'll do complete bleed since I only bled the fronts during the install.
Haynes states the ultimate horror: dealer only to clear that code.
The ABS sensor to the CV joint did not appear to be affected in any way.
Bingo! immediately after posting the above I took one more crack at clearing the ABS light , no go. Then on a short drive it went out. The Volvo dealer: a fate worse than death.
New front rotors, calipers and pads, ABS lite persists
- Has thanked: 2199 times
- Been thanked: 1851 times
Well done on brake noise issue.
The ABS light can be caused by:
1) Bad ABS sensor/wire at a wheel or in the wire near to any wheel
2) A sensor ring on an axle being corroded or dirty preventing the sensor getting a consistent signal
3) A failing ABS module.
The first item can be tested by a resistance test on the wires and comparing them. There are resistance value ranges for these, but don't have that info to hand.
- Has thanked: 311 times
- Been thanked: 817 times
Thanks for adding the link erik
On a 1999-2000, the m8 bolt holding the axle in place will code abs if it is not torqued correctly. It’s 14 mm head. Dont over torque
If you get ABS light after the short burp on first reaching 10-15 mph, the module and pump are probably ok, one of the wheels isn’t right, in my experience.
- befarrer
- Year and Model: 1998 V70 AWD
- Has thanked: 1 time
- Been thanked: 24 times
Also, if you were running the car with front wheels off the ground, so the wheels were spinning will confuse the ABS, it expects some sort of signal from the back, when it doesn't it sets a code for the rear wheel sensors. It resets after driving a bit, usually once getting up to 12mph or so and it sees all 4 sensors.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
- 1678 Views
Last post by jbeebo
- 25 Replies
- 5817 Views
Last post by Gerd
- 19 Replies
- 3291 Views
- 877 Views
Last post by BEJinFbk
- 2249 Views
Last post by fishingdad101
