Strange error. Some days when I start the car it doesn´t charge. Instrument panel are a bit dim and voltage around 11.3 V. After 10 to 20 seconds the voltage goes back to normal. Like 14.4 V. No warning lights or anything.
It it somerthing in the car that regulates charging or only the voltage regulator in the alternator?
No charge for the first 10 to 20 sec
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
How old is the regulator ?
It´s been replaced this year. I´ve found out though that there is three types of possible alternators. 120A, 140A and 160A. My is a 140A but I´m not sure if the regulator was made for that or not. Can a bad alternator cause this problem?
- oragex
Your 2002 has the same regulator as my 2003 and I had the bad idea to put a 'smart' regulator for 2005-up and while it was only charging to 13.5v all time (and ruined my battery), it was charging always the same, including at start up. May try see if you have a chinese brand, with a flash light and a camera to take a pic and focus in, the number should be visible.
- oragex
I'll try to check mine, see if it's charging during a cold start. I think first 20-30 seconds is the high idle
This thread title gave me a tremendous hope for a Few moments but MVS HR censored my thoughts
I’m from Sweden. Probably explains it...
But regarding the car. I’ve now replaced the voltage regulator. The alternator is hard to get out of the car completely but It was possible to make the replacement without taking it out. Just by removing all the bolts
- oragex
Good update. Doesn't it charge now right from the start up ?
- 26 Replies
- 1604 Views
Last post by Brickbox8398
- 9385 Views
Last post by Rattnalle
- 1207 Views
Last post by Bowtiekilla02
- 929 Views
Last post by beigg
- 16 Replies
- 3041 Views
Last post by cn90
