Manual climate controlled 1998 V70 EFI only
When turning the switch on the dash, I am not hearing/feeling the dampers change the direction from which the air is flowing. I believe this means that the switch that causes the dampers to activate is no longer working.
Any thoughts on my situation?
Damper Swtich Not Activating Properly
- misha
- Has thanked: 155 times
- Been thanked: 432 times
MCC doesn't have damper motors.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2197 times
- Been thanked: 1850 times
I have never seen a MCC unit on a P80, but from what I recall from reading posts over the years is that the cable operating the flaps can get stiff and pull off the unit under the dash. I can't recall from memory if the arms are metal or plastic (I think plastic) but they may have broken or jammed.
Sorry I can't be of more help.
- Been thanked: 4064 times
MCC on late 1998 is cable controlled air temperature, left and right, and motor damper controlled air distribution and fresh/recirculated air
If you get only fixed air temp after warmup, the cables probably popped off
CEBirnley
- Year and Model: 1998 V70 Base FWD
- Has thanked: 13 times
I dont think I am explaining “things” correctly. Essentially I only have air coming out through the defroster area and dash vents. I am getting no air to the floor, regardless of where I place the switch. I think my system is MCC as I dont have temps listed, only the blue and red colors on the temp controller.
Thank you all for your input and hopefully this clarified my issue.
It’s we who are confused , you were clear.
You do have dampers, not cables controlling air flow on your 1998 if it is like mine.
Pull the driver kick panel down and see if you are getting any noise from the motors on the sides of the white climate unti. Look up and see if the linkages are in place.
Part 12 in this diagram
- 11 Replies
- 3103 Views
Last post by jonesg
- 16448 Views
Last post by precopster
- 1179 Views
Last post by Mike Langlois
- 486 Views
- 248 Views
Last post by joadahle
