Dash center console light bulb replacement
chefmarkt69
Year and Model: 2009 XC90
Post by chefmarkt69 »
Would anyone know how to replace the light bulbs in the heated seat switch? Also does anyone know what kind of light bulbs they use? Thank you
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
If I recall the heater control panel has to come out. There should be two screws visible once the panel at the bottom is pulled off. Then if memory serves me you will encounter one plug harness and the cigarette harness.
BE CAREFUL - if you don't unhook the battery and remove the main harness to the panel memory tells me you will cause an SRS (airbag light) to be triggered.
Once the panel is out you can access the bulbs - I don't recall the part number but some switch them to LED.
