855 headliner question.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Will a V70 2000 headliner fit an 855? I want to replace the entire roof liner, pulling it out the back. There appear to be minor trim changes in models, I wonder if that matters. Are the V70 headliners more robust, somehow? Is the sunroof plastic trim piece still available from Volvo? Maybe later models have stronger trim pieces. No way not to break this piece just touching it. I know, that's a few questions rolled in to one.
- Cookeh
- Year and Model: 1996 Volvo 850 T5
- Has thanked: 77 times
- Been thanked: 59 times
I know things get, well, bizarre in the MY99-00 cars so this may not be applicable. I put a MY98 V70 headliner into my 850, and everything went in perfectly. The two were identical in construction materials and weight, so I don't think they're more robust personally.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
Just recover what you have.
I've done it on both our cars (sedan and wagon). There is a trick to getting the sunroof trim off that I haven't been able to master, but it really didn't matter to me, as I replaced it with some of THIS STUFF dyed to what color I needed.
This is what we did to the wife's '97
Wow,.....that’s really....busy!
- Chuck W
She likes it. (I told her to pick the material)
There's a lot of more "standard" material choices available out there. I've done probably 6-8 of them on different cars over the many years.
Matching door cards.
rguzz
Thanks, I saw the other posts, looks great. I could just re-cover mine but...I still need to remove the roof liner. Maybe I'll pull as many plastic pillars/trim pieces from the picnsave, with the assumption I'll break a bunch of stuff, and go for it.
- Chuck W
The A-pillar trim are pretty stout, but the B-Pillar ones are can be delicate, due to their size. The over-the-door bits aren't too bad.
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 672 times
- Been thanked: 163 times
The point is that each one will choose his own material.
The thing also is : that's a great job !
Congrats !
Manov
Congrats !
Manov
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I believe Volvo still sells the sunroof trim, about $25 US.
I also installed a V70 liner in my 855. Now it's due material replacement.
When replacing the material, make sure you shake the can very well or the glue will NOT stick long.
- 2171 Views
Last post by QuirkySwede
- 662 Views
Last post by sclark0711
- 385 Views
Last post by Baptiste1106
- 2919 Views
Last post by rspi
- 26 Replies
- 6927 Views
Last post by 98v70dad
