viewtopic.php?p=554497&hilit=Nautic+blue#p554497
Build date 8/98 Ghent (early 1999 model year Build)
Beautifully maintained and clean 417 Nautic Blue wagon
Driver power seat fore aft inop
Evap circuit not ready
Removed cover in fall amd retorqued head bolts, seep seems to be alleviated?
Replaced rear calipers and rear brake pads
Radio code 4111
Cruise control inop, found loose plug at wheel. Now working
Courtesy lights inop, loose plug at console. Repaired cracks with epoxy
2021 sercvice records
March2 oil change at 233500
Replaced console light with new from Tasca, repaired heater box vacuum hose with 3 mm silicone blue
1April Replaced muffler with FCP STARLA
Order #:
R443273752
Snout to bell was a bit loose so sealed with putty and permeatex epoxy wrap, clamp. Installed driver kick panel
Pulled Shaggkira driver seat, shampood carpet.
Fore aft motor stuck on driver. Tested motor, stalled. Removed motor, runs. Gear box apparently seized, or runners seized. I used my other 99 to mark a seat position that fits three ladies that drive this car and set the runners there.
Swapped in a nice arena/ wood console and swapped in driver kick panel.
Fixed shifter knob by trimming plastic to allow release.
July 2021…replaced radiator to reservoir hose due to hole from ps pulley abrasion. Added 1 liter make up oil at 237300
Installed 2019 battery
Drain fill 4 liters atf valvoline max life dex6
Replaced o-rings on upper atf hose
238400 new Volvo 3 prong plugs. Coils date 2015. Car is popping a pretty quick P0440 for major evap leak. Rear canister style. Volvo code is ECM4047 vap canister shutoff valve blocked or canister purge valve leakage Inspected j and L j]hoses, appear ok
239200. R/r front left wheel bearing with FAG. Treated and painted brake backing plate with hammertoe. Installed 9492980 Volvo wheel seal
viewtopic.php?f=1&t=45096
Swapped I working power driver seat from Dirk
Welded 60 mm bosal cat pipe to Starla muffler
Oil change filter 241041 August 30 2021 10W-30 Castro’s synHM
Installed air guide. 8mm head bolts instead of 10mm
November 11 242732 added one liter make up oil
Replaced right from headlight wiper
