Permanent Live
jking4020
- Year and Model: 1997 850, 2001 v70xc
- Been thanked: 3 times
Find the, usually red, constant hot feed wire to your radio and splice that into your hot wire on the socket. Or even better by a long wire with an inline fuse and attach it to an empty constant hot port on the fuse box. If you plug in something that's taking in too much current it will blow that fuse and not kill your battery if you forget it's plugged in. All radios have a constant power feed wire.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
you mean like the one at the back cargo area?, that gives you a dash warning which is a good idea but can run your batt down. i have a few things like my radio/security cameras running from seperate delay off relays that way it runs for a set time without running the battery flat. Ive spliced the radio +12v wire which is fused.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- 3610 Views
Last post by Blacklab467
- 722 Views
Last post by theWIFES_S70
- 1488 Views
Last post by misha
- 505 Views
- 2187 Views
Last post by eightfifty2x0
