2011 XC60 P0420 Code
xyourobob
Year and Model: 2004 XC90, 2011 XC60
Been thanked: 4 times
Post by xyourobob »
Happy New year to everyone. My 2011 XC60 T6 with 150K miles threw a P0420 code, my hand OBII wouldn't clear the code so I hooked up VIDA and sure enough the ECM fault code "Catalyst System Efficiency Below threshold (bank 1)" was there. Funny enough I was not able to delete the code using VIDA, most times a failing O2 sensor will throw this code and you can clear it and then the code will come on again somewhere in the imminent future but I can't understand why I can't clear it? When I click Erase All I get a communication fault message, car not responding? I'm assuming I will have to purchase a new downstream o2 sensor but can anyone shed any light on why I cannot clear the code?
xyourobob
Post by xyourobob »
Buzz!!!!
xyourobob
Post by xyourobob »
I ordered a new sensor for less than $100. It was fun removing the old one, heating it up with a propane torch did the trick. After installing the new sensor I disconnected the battery for 10 minutes to clear the code and so far so the engine light has remained off.
Dzikiewicz
Year and Model: 2011 xc60
Post by Dzikiewicz »
I have the exact same car with the exact same code, is this still cleared for you? if you search this code for other P3 Volvos you can see this can be a hole of a problem.
