2005 S80 2.5T, 220k
There is an intermittent loud "clacking" sound that seems to be coming from my power steering pump. There are no leaks, the reservoir is at the proper level, and I don't seem foaming or odd coloration. The pulley feels solid, no wobble. The power steering assist works fine.
Is this a sign that the power steering pump is about to go kaput? If so, I can make a run to the junkyard and swap it out.
Or is there some mystery piece inside the reservoir that could be limiting circulation? I've seen some posts about something like this, but not sure what to look for.
power steering "clacking" noise
- RickHaleParker
- Been thanked: 978 times
Did you inspect the AC clutch?hu5ker555 wrote: 04 Jan 2021, 08:33 There is an intermittent loud "clacking" sound that seems to be coming from my power steering pump.
Active
Past
Past
hu5ker555
- Year and Model: 2008 S60, 2015 S60
- Has thanked: 46 times
- Been thanked: 18 times
No, I did not. What should I be looking for? Maybe I should remove the serpentine belt and see if any of the pulleys (PS, alt, A/C, tensioner) are loose or wobbly?
hu5ker555
UPDATE
So upon closer inspection, noticed that the ENTIRE belt tensioner pulley was gone. The belt was riding on an empty shaft!!!
Never seen anything like it. There was just enough tension to run the PS, alternator, AC somehow. Not sure how the pulley disappeared, but the belt stayed on. Maybe since the pulley is plastic, it just disintegrated.
Either way, went to the junkyard, pulled off a belt tensioner, put on a new belt, and away we go.
- ndphotonl
- Year and Model: 2001 S80 2.4T
- Has thanked: 27 times
- Been thanked: 33 times
Wow crazy, did you make any pics?
Why not a new belt tensioner btw?
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
FlickR images
hu5ker555
No pics. I have easy access to several junkyards and actually prefer obtaining parts there myself. This way I can be certain how best to access the components, try out a few things, and then tackle the job with confidence. Fairly straightforward job. The top bolt on the tensioner was accessed from above. The bottom bolt through the wheel well. Remove the tensioner through the wheel well. That way the PS pump can remain in place.
