So my pump quit on me, of course I just filled up.
I’m desperately trying to figure out how to get the 19 or so gallons out with little luck. I’ve tried siphoning, but the filler neck seems much too curvy to be possible. I’ve looked at trying to do the fuel filter but don’t know how I’d get the gas out from there (connect the line to a pump/siphon?) or would it drain on its own? I’m also looking at trying to disconnect the filler tube near the tank but it seems fairly difficult due to the space and their pretty seized together, I’d worry wiggling it too much would leave me with a broken filler neck.
Can anyone PLEASE give me some insight. The manual says to drain via the filler neck and that’s all. Doesn’t seem possible?
Thanks,
Jack
1998 v70 awd glt
Tackling p80 Awd fuel pump
Undo the fuel line at the rail and jump the fuel pump relay under the fuse box. You will need about an hour to pump out a full tank
- Has thanked: 2199 times
The problem is that you have no pump available as you stated. Volvo also made it difficult to get a hose down the fuel filler pipe to try to prevent siphoning by bandits. The pipe is not too bad to get to the tank. However, as it is a saddle tank you may only be able to empty the passenger side of the tank as it needs pressure to push the gas from the LHS to the RHS.
It may need a 2 prong attack. First a small diameter flexible hose (maybe 1/2" ID) and try to push that down into the RHS of the tank and get one of those cheap hand pumps to try to pull the fuel out of that side.
Then step 2 may be to remove the downstream side of the fuel filter, connect it to a bucket with a pipe and try to pressurize the tank to see if it will transfer the other half of the tank into the RHS and out the filter into the bucket. You could do this actually for both sides. The caution here is to keep the pressure to a reasonable level not to damage anything, as most of the fuel hoses are NLA. The fuel pressure is 43 psi approx at the rail, so that should not be exceeded.
I cannot think of any other way to extract the fuel as the pipes all run upwards from the tank.
Maybe Jimmy57 can give a suggestion on this?
Well if you are just replacing the pump and are planning to do the floor cut access in the rear footwell then that is ok. If you are planning to drop the rear sub-frame and tank assembly then that may not be enough.
Some days my moronic brain function even astounds me.abscate wrote: 05 Jan 2021, 14:53 Undo the fuel line at the rail and jump the fuel pump relay under the fuse box. You will need about an hour to pump out a full tank
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
If you can get a pump hooked onto the fuel rail you should still be able to siphon the tank near dry on the pump side. That said, it's going to be a long process...
Happens to the best of us! Thanks for your reply
I was thinking about that, but couldn’t figure out how to go about it. Was wondering if a cheap inline pump would hook up somehow.wizechatmgr wrote: 06 Jan 2021, 08:12 If you can get a pump hooked onto the fuel rail you should still be able to siphon the tank near dry on the pump side. That said, it's going to be a long process...
- 1546 Views
Last post by azureblue
- 42 Replies
- 12026 Views
Last post by Maestrours
- 13 Replies
- 3609 Views
Last post by matthew1
- 2164 Views
Last post by precopster
- 681 Views
