No high beams -- 98 V70 Manual
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
I have low beams and parking lights. When I go to engage the high beams it doesn't flash and I get nothing on the dash.
I'm thinking relay, fuse or switch/stalk. I'll be checking the requisite fuses tomorrow. I know it blew an alternator, so it's possible the high got hit if it were engaged at the time.
Anyone know the failure likelihood on each of these with exception of the fuse? Do we have any chopped up schematics?
And for those wondering, it's darn near impossible to solder abs harness wires. I don't know what is up with them but I think the next time I'll try acid core solder.
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
Hope it will help.
Manov
Volvo 850 Electricals diagrams .pdf
(2.57 MiB) Downloaded 110 times
Has thanked: 1609 times
Been thanked: 4064 times
I would check bulbs first. I’ve got spares to swap in the driveway.
manovlov
Post by manovlov »
I had thought this step had been done first. Hence the electrical diagrams .
But yes, you have to check the bulbs first.
It's still Abscate who wins a box of chocolate!
Abscate, how dare you ? :D
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Any voltage at the high-beam sockets?
Most susceptible to high voltage?
I’d look at the hi/low headlight relay.
And here’s a fuse legend:
wizechatmgr
Thanks all, will be giving it a crack either tonight or tomorrow morning.
We will add any bright ideas here.
manovlov
Post by manovlov »
abscate wrote: 07 Jan 2021, 19:32 We will add any bright ideas here.
:D
Interesting
The stalk bypasses the light relay. So if the bulbs test good, you can rule out simple relay failure with the stalk test.
Fuses 11C/19-22 and 11C/13 are relevant too
wizechatmgr
abscate wrote: 08 Jan 2021, 06:44 Interesting
I'll try to test that tonight if I get any time.
For those wondering, don't wash an NA with a distributor cap if you aren't sure it'll stay dry... Don't ask how I know =(
