850 Rear Mounting Bracket
crlwalls
Year and Model: 1997 850 N/A
Post by crlwalls »
I am curious to know if one can change the bolts in the rear license plate mounting bracket. Like could I remove the rear tailgate interior panel and change the bolts from metric to standard or vice versa?
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
For GPs or are your bolts stripped or something? You could change them, but it may not be the best option
Current Volvos:
Has thanked: 1609 times
Been thanked: 4063 times
You can buy a new plate holder for about $18 from FCP, part 31391626 . IT screws into rubber bushings in the trunk with Torx screws. M6 acorn “stainless “ nuts from Lowe’s or other hardware store work well here
A dab of anti seize helps keep them from rusting up.
I’ve been more sensitive to plate holders since I’ve been shuffling which members of the fleet are registered
( For our UK membersrecoiling in horror, most States here assign plate to registrant, not to the car. It’s yet another reason you have nice things )
