G' day folks,
I'd been noticing my temp gauge running lower and lower over the past couple of weeks.
Now I've a cold running engine - gauge barely gets off of the bottom. Coolant level is good.
The cooling fan is on continuously - from start-up.
The engine does not go through the warm-up cycle, but starts normally.
The quick fix is to disconnect the fan and replace the thermostat.
Where should I be looking?
Mucho Gracias, Dudes
No warm-up sequence, cold engine temp, continuous fan
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
Don't disconnect the fan.
Are you getting heat in the cabin from the heater? If so, replace the temperature sensing unit. If not, replace the thermostat. I'd start here 1st.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It's usually the module (silver box) on the fan assembly that goes bad. You have two capacitors inside, Hella. May cut the wires to the box, swap it, and weld back the wires
- 3537 Views
Last post by 93ForMe
- 1356 Views
Last post by FLXC90
- 747 Views
Last post by waynegarbo
- 13 Replies
- 2459 Views
Last post by RickHaleParker
- 225 Views
Last post by firstv70volvo
